15 Sep 2023 07:18 PM
can I connect my Sonos Beam to my Sky Glass tv? I read that yiu can setup the sound using a sky puck remote, however I need to use only one remote, ie my sky glass rmeote to control everything including the sonos beam for sound. Is this possible?
04 Apr 2024 06:53 PM
Hi,
I got my sonos beam 2 today and finally managed to connect it.
I connected to the hdmi arc but the sonos app connection kept failing the cec connection. I had to disconnect power to the sky glass and start it up again and it worked.
The sky glass tv control then didnt control the sonos. You need to turn the remote from rf to iR by pushing two buttons at once, i forget which two but goggle it and you'll be fine, so it makes the remote control use IR.
Then via Sonos app you can add remote control and go through the process on app to add it.
Wohoooo, an hour ago i was nearly sending the sound bar back. Well happy as the difference is amazing!
