Discussion topic: Channels taking too long to load
This message was authored by: Raymond17
My sky glass won't load
Re: Channels taking too long to load
First thing to try is a reboot:
1. Go to Settings
2. Go to System Management
3. Press Select
4. Go to Resets and Updates
5. Press Select
6. Go to Restart Device
7. Press Select.
Note this will take a few minutes to reboot, so expect to see a blank screen for 2 minutes until the Sky logo appears as its starting up.
If the reboot doesn't help then it sounds like the cause may well be the strength of the internet connection the TV is getting. How do you have it connected to the internet via Wifi or ethernet?
Sky Stream and Sky Broadband customer
Avatar for Raymond17
I am after getting sorted thanks for all the help.
What was the outcome of the Restart?
