Discussion topic: Changing Input on Sky Glass without remote (or voice control)
This message was authored by: BeckieTR
Hi,
I'm in a situation where I'm waiting for a replacement remote from Sky, which is taking a while but I need to be able to switch to a HDMI input.
How can I do this without using the remote or voice control?
Re: Changing Input on Sky Glass without remote (or voice control)
Have you turned off the 'hello sky' voice control function that doesn't require a remote?
Avatar for BeckieTR
Thanks for your response Mark. We don't actually have that function as we dont' have a sky ultimate subscription as we literally only use the TV for streaming services rather than Television channels.
The function comes with the Glass TV by default. You don't need a Sky Ultimate subscription. See the help here: https://www.sky.com/help/articles/voice-control-sky-glass
This message was authored by: Mister_Dalek
Not according to that link. Which states:
Voice control is only available on Sky Glass with a Streaming TV subscription
Well you learn something every day.
Apologies,to @BeckieTR  if I inadvertently misled you,
