Discussion topic: Can Sky glass connect to SkyQ while I wait for faster fibre.
This message was authored by: mrvivers
I have a Glass Tv being delivered on the 12th, can I connect this to my sky Q box while I wait for the fibre 300 to be activated on the 25th, I don't think my current fibre (Fab 75 from Now) will be fast enough for the Sky Stream?
J
Re: Can Sky glass connect to SkyQ while I wait for faster fibre.
@mrvivers  Unfortunately not your Q subscription contract will have been cancelled
@mrvivers  You won't be able to continue using your Sky Q TV as that will be deactivated once Glass is setup, howver if you mean can you use your current broadband setup, then yes you can.
Avatar for mrvivers
Hi,
I was hoping I could use the glass tv like normal tv with sky q until the full fibre get activated. But I'll just have to set the tv up and hope the current BB is suitable. 🤞🏼
@mrvivers  As long as you can get a minimum of 25mbps for HD & 30mbps for UHD you should be ok.
This message was authored by: peter-marlow+1966
You  can while are waiting for the packaging  to arrive  for you sky equipment  to be returned,  also bear mind that you will have two sky bills 2 pay next month 1 for  your  sky glass  subscription  and the last 1 for sky q
P c marlow
You can still use sky q for channels  like bbc and itv you will lose all the sky channels and  functions  and your recordings
P c marlow
