Discussion topic: Can I connnect sky glass to my sonos sound bar and off so how. Thanks in advance
This message was authored by Maiden63 This message was authored by: Maiden63
Can I connect Sonos sound bar to sky glass.  Spoken to Sonia and they said I need an optical sound port and cable
Re: Can I connnect sky glass to my sonos sound bar and off so how. Thanks in advance
@Maiden63
If the Sonos is compatible with eARC or ARC then you'd use an HDMI cable from HDMI #2 on the Glass set.
If it's optical input only then you'd have to obtain an eARC to optical-audio extractor: the Glass television has no optical audio port.
This message was authored by Lady+Caz This message was authored by: Lady+Caz
I jist connected my beam to the hdmi arc but initially the sonos app failed the cec connection. I had to completely remove power, power lead out for 30 seconds from tv and start uo again. It then realised the new hdmi connection and allowed cec connection.
