188
Discussion topic: Amazon Prime blank screen but sound
This message was authored by RogueTrooper1 This message was authored by: RogueTrooper1
Re: Amazon Prime blank screen but sound
New customer to Sky, been with them less than a week - Same problem with Prime as everyone else on our Glass tv - Pretty worrying given that we use Prime a lot. Also, WiFi signal strength is just woeful.
Already regretting signing up to Sky.
This message was authored by Fothergill1 This message was authored by: Fothergill1
@RogueTrooper1 It is completely your choice and I'm not trying to influence you but just a reminder that if you feel Glass is not for you (for any reason) you have a 31 day cooling off period during which you can cancel your Sky subscription free of charge and get a full refund for your Glass TV.
If my post has solved your issue please mark as an "Answer"
This message was authored by Desjan This message was authored by: Desjan
Re: No Picture blank screen on Amazon
Sky glass will not play video content on Amazon. I have a puk on my Sony TV in another room . I play Amazon prime on my iPhone then stream to my TV. It will not work on Sky Glass TV for some reason
This message was authored by Davy58 This message was authored by: Davy58
Didn't play on mine either for ages but has been ok last few days, just checked and still playing fine...
65inch Sky Glass, 2 Sky Streaming Pucks, Sky Superfast Broadband
This message was authored by Sammiewind This message was authored by: Sammiewind
My Amazon has been working for about a week and is still working
I have a sky glass 55inch
This message was authored by Madskitzo This message was authored by: Madskitzo
So I've had my sky glass tv now for a year, suddenly today this started. Haven't done anything, just turned on prime and no picture. Works ok on my other sky glass still which I've only had for a week.
tried to reset apps, no luck.
reset apps, turned tv off for 60 seconds (at mains), no luck.
reset tv totally, no luck.
reset tv totally, turn off for and hour (at mains), no luck.
nothing I have done has made a difference, blank screen but have sound.
This message was authored by darkdan This message was authored by: darkdan
Hi I'd like to report this issue has occurred again on my sky tv just a complete black screen on the prime app, rest the apps reset the tv fault remains
This message was authored by rw123 This message was authored by: rw123
Yep me too
This message was authored by KerrieA1 This message was authored by: KerrieA1
Sorry for taking a while to feedback - the only solution I have found that up till now has worked was to quite literally uninstall app and unplug everything from the mains (TV, firestick, puck & wifi) - leave unplugged for around ten minutes and then reconnect, reinstall and log all the way back in.... basically in millennial speak reboot the whole system. I've not had any issues since however I did turn my tv off at the mains plug for a few nights on the trot too. But yeah since I did all that I've not had the recurring black screen issue. It's long but it's worth a punt. Amazon, Sky, Toshiba help centres all blamed each other and gave condescending tones of advice. Hope this works for someone else 👍
