Discussion topic: 65inch sky glass wall mount
This message was authored by: Mckennam
Hi can anyone please help me I have a 65inch sky glass tv I want to put this on the wall how do I go about this in the wall bracket in the stand ? And can I use any bracket for example for £60 from Argos that takes up to a 90 inch tv
Re: 65inch sky glass wall mount
You can use a VESA wall mount according to other posts I've read, if you didn't order one with your TV. You do need to make sure your wall mount can support the weight of the TV - as you know it's a heavy bit of kit!
@Mckennam the main consideration is going to be weight. Sky Glass is a heavy TV. Do you have Gen 1 or Gen 2?
Avatar for Mckennam
Thank you I've ended up ordering one that can hold 90kg a heavy duty one from amazing hopefully this will work xxx
Cool. Make sure you use wall plugs / anchors that can also cope with that weight else you'll have a big mess on your hands.
@Mckennam
https://www.sky.com/help/articles/sky-glass-wall-mounting-guide
