Discussion topic: Swissvoice 2355 compatibility with sky hub
This message was authored by: Emma0667
Hi, I'm thinking about buying a Swissvoice phone for my elderly father who is partially sighted.  He has a sky hub at his home and I was wondering whether the Swissvoice 2355 is compatible and whether sky microfilters are needed for each handset? Thanks
Re: Swissvoice 2355 compatibility with sky hub
@Emma0667 providing the phone is designed for use in the UK and has a standard BT phone connection to the phone line it should be ok. No microfilter is needed if the phone plugs into a Sky broadband Hub.
As mentioned above.
Looking at the manual online, it will work fine with a Sky hub.
As it's a dect phone and assume you may want an extra or more  phone handsets in different rooms, only the main base station needs a connection from the base station to the Sky hub. All the other handsets will connect through to the base station.
If the property still has a phone connection to a wall phone socket with a micro filter,, then the base station will also connect to that fine.
