Discussion topic: Having problems with signal stregth and quality. Input 1 strength is 95% and quality only 30%.
This message was authored by: Keith62.
Message posted on 07 Jul 2022 07:05 PM
Having signal problems
Input 1 strength 95%
Quality 30%
Input 2 strength 60%
Quality 50%
What could be causing low quality on Input 1.
Find out more
Message posted on 07 Jul 2022 07:07 PM - last edited: 07 Jul 2022 07:28 PM
Re: Having problems with signal stregth and quality. Input 1 strength is 95% and quality only 30%.
@Keith62. Which box do you have Sky+ or Sky Q?
The forum you've posted in is not the correct one so your post will need to be moved to the correct one when you advise which box you have.
