Discussion topic: How to listen to audio in background when using sky sports app
This message was authored by: Selbstlader
Hi there,
How can I listen to the audio commentary of sky sports after exiting the app or turning off my phone screen?
I'd like to hear F1 or premier league commentary but exiting the app stops the feed from playing. Is there a way to listen to the feed like a normal radio channel?
Many thanks. If not possible, hopefully sky can implement a solution.
Re: How to listen to audio in background when using sky sports app
There is no way to do this because as you said when you exit the app the sound will stop. I can't see this being implemented either as there is no need for it.
This message was authored by: rbraintree
Who says?! - I for one have need of it
And there you have it, one customer is not justification to spend money and time developing a feature
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
