Discussion topic: Eden Sky Card
This message was authored by jordd This message was authored by: jordd
Eden Sky Card
Hello,
I have recieved my incenive award edenred card for £75, but now whenever I'm attempting to activate the card so I can use, it's prompting for my sky accunt number. The sky account number, I have within the MySky app does not work, it shows as invalid. Can someone tell me where I would find the correct information
Re: Eden Sky Card
Are you a new customer to Sky or were you a customer in the past who has returned after being away for a year or longer ?
jordd
Re: Eden Sky Card
no, I'm a new sky customer from around November 2021
jordd
Re: Eden Sky Card
I tried this mulitple times and have been stuck on the sky account number bit, but doesn't appear to take it the details
Re: Eden Sky Card
It might be worth getting in contact with Enenred about this:
https://www.edenred.co.uk/reward-recipients/how-to-use-my-incentive-award-card/spend-my-incentive-aw...
jordd
Re: Eden Sky Card
But it's prompting for a sky account number,
Is there not a way you can locate this information,
As going to them they'll only point me back to you guys
jordd
Re: Eden Sky Card
Above is the error im getting. To find my sky account number I logged into the mysky app and located the broadband and talk bill and it shows my account number under there, but im getting the error
This message was authored by Mark39 This message was authored by: Mark39
Re: Eden Sky Card
Be aware we're customers here. You're not talking to Sky. If you're entering your account number correctly, there may be some sort of technical issue with Edenred preventing it being accepted, hence the suggestion to contact them. You could, of course, give Sky a ring and confirm your account number with them too.
This message was authored by DamoTheUnstable This message was authored by: DamoTheUnstable
Re: Eden Sky Card
i also have a edenred card i just recived today, but apon clicking next it does nothing, rung the number to try and activate it but its all in belguim, cant find a way to activate it in the app
sorry for bumping an old thread but i am lost on what to do
Re: Eden Sky Card
@DamoTheUnstable  If you having the same issue then the same replies would also apply to you.
Re: Eden Sky Card
im getting no errors, just the next button litterly does nothing, what is the point of these cards if you cant activate them,
Re: Eden Sky Card
Spoken to Edenred?
This message was authored by S+mcm This message was authored by: S+mcm
Re: Eden Sky Card
I keep getting stuck in the stage 3 part of activatjng it just comtinually loads but nothing seems to appear! Definitely frustrating !
Re: Eden Sky Card
@S+mcm  Have you contacted Edenred?
This message was authored by Red+snapper This message was authored by: Red+snapper
Re: Eden Sky Card
I seem to have found the Edenred card failures club.
I received an email with a contact number to receive  a PIN . Every time I called the number never even rang just hung up immediately!! Tried at least 20 times over the 24 hour time limit- no success. Emailed asking they post the PIN, just got same response " call this number quoting the pass code and receive PIN". Same outcome. Some incentive this from Sky!
 Just give me the amount deducted from my bill!
On average, new discussions are replied to by our users within 7 hours
