Program the Sky+HD remote to control a Sound System
Please note: Sky does not currently support Sound Bars but the manufacturer codes below may work.Please note: Sky does not currently support Sound Bars but the manufacturer codes below may work. Things you should know before you get started
  • This function is only available on Sky+, Sky+HD, Sky+HD Terabyte and Sky Navigator remote controls.
  • The version of the Sky remote should be Rev.6 or greater. (Found under battery cover)
  • Not all amplifiers / Home Cinema systems are compatible with the Sky remote.
  • If a manufacturer code is available and it is compatible with your amplifier, it will control the standby, volume up and down, mute and input selection amongst others.
Handy shortcuts available on Sky+HD remote
Program your Sky Remote
Did you know you can program your Sky remote to control your TV as well as your Sky box?
Manufacturers and Amplifier Model Codes
Please select your code below then click here and follow the instructions. If you have no code for your system below it's not currently supported.
Amplifier Manufacturer Amplifier Model Code
Note: Codes in bold are for Rev.9 remote controls
Acoustic Solutions 1496 1498 1529 1474
AEG 1418 1417
AFK 1417
Aim 1418
Aiwa 0149 0187 1433 1086 1186 1286 1650 1850 1750
Akai 0374 0143 0468 0637 1248 1418 1206
All-Tel 1418
Amstrad 0772 1418
Anam 637
Apple 1143
Arcam 0669 1117 1217 1240 1297 1317
ASCOMTEC 1417
Audiolab 1117 1217 1297 1317
Audiosonic 1417
Audiovox 1436
Audioworld 1418
Balanced Audio Technology 1117 1217 strong>1297 1317
Bang & Olufsen 827
Basic Line 1409 1582
Belson 1409 1417
Binaura 1723
Blue Sky 1418
Bonnec 1217
Bose 1257 1281 1657 1383 1385 1961
BSkyB 1525
Bush 0449 0875 1117 1217 0825 1297 1317
Cambridge Audio 1675 1217 1758 1483 2010
Cambridge Soundworks 1499
Carver 388
CCE 1380
Centrex 1285
Centrum 1582 1248 1417
Classic 1380
Clatronic 1248 0772 0825
Copland 1117 1217 1297 1317
Cosmotron 825
Creative 1499
Curtis Mathes 328
Daewoo 1206 1278
Denon 1388 1132 0300 2885 0032 1462
Denver 1417
DeToma 1123
Diamond 1418
Digitrex 1285
DiK 825
DK digital 1448
DMTECH 1418
Dual 1248 1418 1448 0032
Durabrand 1596
eBench 0772 0825
Electrocompaniet 1217
Elta 0772 0825 1418
Enzer 1409
Eroica 468
Fisher 388
Garrard 0468 0772
Genexxa 0214 0468
Goldmund 1117 1217 1297 1317
Goodmans 0637 0772 0468 0825 0374 1206 1227 1448 1417 1525 1618 0449 0875
Grundig 0875 1496 1117 1217 0772 1372 0825 1297 1317
Grunkel 772
Hanseatic 1418
Harman/Kardon 1332 1338 1117 1217 0138 1334 1297 1317
Harwood 772
HCM 1418
HE 1417
Hitachi 1372 1248 1582 1809 1811 1227
Hiteker 1417
Höher 1285
Home Tech Industries 1417
Inkel 0519 0530
Integra 1833
Intersound 772
Jamo 1592
JBL 0138 1334 1205 0696
JVC 0102 0492 1523 1402 1704
Kenwood 1341 1055 1597 0214 0290 1321
Kinyo 1123
Kiss 1592
Kompernaß 825
Koss 772
KXD 1417
Lenoxx 1417
LG 1321 1552 2225 2417
Lifetec 825
Linn 1117 1217 1297 1317
Loewe 1117 1217 1297 1317
Logitech 1436
LXI 772
Magnat 1205
Magnum 1629
Marantz 0349 0669 1117 1217 1297 1317 2142
Mark 1117 1217 1297 1317
Matsui 0825 0772
MBO 1380
MCS 374
Medion 0825 1448 2225
MEI 1418
Melectronic 637
Meridian 1117 1217 1297 1317
Metz 1582
Micromaxx 1448
Micromega 1117 1217 1297 1317
Microstar 825
Midiland 1123
Minton 1123
Mitsubishi 468
Musical Fidelity 1747
Mustek 1380 1618
Mx Onda 0772 1525 0825
Myryad 1217 1117 1297 1317
NAD 0348 0637 1771 2017
Naim 1117 1217 1297 1317
NEC 1278
Nexius 1418
Nikkai 1417
Nikkei 772
Okano 0468 0637
Onkyo 1348 0163 1833
Optimus 214
Orava 1417
Orient Power 772
Oritron 1525
Palladium 0825 1248 1552
Panasonic 1807 1546 1791 1793 1337 1336 1344
Paramount Pictures 1248
Philips 0669 1646 1217 1117 0374 1701 1297 1317 1294 1682 1859 2339
Phonotrend 530
Pioneer 0328 1051 0317 0214 1151 1212 1117 1217 1312 1487 0851 1297 1317 1651 2132 1963 1851
Prima Electronic 825
Proline 0825 1418 1285
Proson 637
Provision 1417
QONIX 1448
Quad 1117 1217 1297 1317
Quelle 1206
Radiola 1117 1217 1297 1317
Radionette 1321 1662
RadioShack 772
RCA 374
Red Star 1409 1417
Reoc 1409
Revox 1117 1217 0214 1297 1317
Revoy 1117 1217 1297 1317
Roadstar 0374 0825 0875
Rotel 0821 2031
Saba 1182
Saisho 374
Samsung 1227 1452 1323 1609 1896 2165
Sansui 0349 0637 0374 1117
Sanyo 0388 1829 0772
Schneider 0772 1418 1206 1227 1248 0138
SEG 1278 1582
Sharp 0214 0290 1642 1662
Sherwood 0681 0530 0519
Siemens 637
Silva Schneider 1552 1321 0825
Sky 1525
Sony 0187 0717 1186 1886 1786 1086 1686 1286 1650 1850 1786 1482 1586 1469 1750 1140 1850 2200
Soundwave 637
Sunstech 1448
Sven 1596
Synn 1409
T+A 1714
TaeKwang 468
Tag McLaren 1217
Targa 1321
TCM 825
Teac 0449 1227 0825 0637 0772 1418 1206 0138 1637
Technics 1791 1546 1807 1337 1336 1793 1344
Techwood 1582
Telefunken 0875 1418 1417
Tevion 1629
Thomson 1382 1525 1182
Thorens 1217 1117 1297 1317
Thorn 772
Toshiba 1600
Trice 1596
Uher 374
United 1418
Universum 1206 1248 0825 0637 1418 0772 0468 1117 1217 1637 1297 1317
upXus 1474
Venturer 1418
Victor 102
Videologic 1123
Vieta 1205
Voxson 1448
Waitec 1380
Watson 825
Wellfund 772
Welltech 825
Wharfedale 0468 0637 1418
Xenon 1417
Xitel 1143
X-Tensions 1123
Yamaha 0171 0876 0382 0204 1304 0740 1359 0214 1843 2049 2089 2144 2370 2365
Yukai 1380
Zenith 772
Leave a comment
Comments (3)
Any other potential codes for Sharp? I have a ht-sb100 model and none of those listed above for Sharp work.
I'm trying to program a new Sky + HD remote (v9) to operate a Marantz SR7009 receiver:  I've tried all the codes in the table but none of them work.   I successfully programmed my previous (and now ageing) remote (also version 9) some time back but stupidly didn't keep a note of the code I used.  Has anyone here managed to achieve a remote/Marantz link up?   Many thanks.
How do I know which 4 digit code to use when there are 7 listed for Panasonic?
