How to program your Sky remote control
Bought a new TV? Find out the right code to control key functions, including the volume, with your Sky remote.
Sky+ HD
First and foremost:
Check out some handy shortcuts available on your Sky+HD remote
Once you have the new code, follow the steps below.
(Take a look at the video at the bottom of the page for help following these steps.)
  1. Press TV,
  2. hold Select and Red until the light blinks twice.
  3. Enter 4 digit code XXXX
  4. Press Select
  5. Adjust volume to check this has been successful.
Sky Q
We can't guarantee that every TV can be operated using a Sky remote. If you haven't found a code that works for you, ask the Sky Community.
Leave a comment
Comments (3)
