- Mark as Read
- Report comment
Mark-Br
If you've got a new TV then let me help you find the right code to control key functions, including the volume, with your Sky remote.
Simply follow three easy steps;
- Find out which version remote you're using
- Search for likely Codes
- Follow our step-by-step guide
Once you have the new code follow the steps below.
(Take a look at the video at the bottom of the page for help following these steps.)
- Press TV,
- hold Select and Red until the light blinks twice.
- Enter 4 digit code XXXX
- Press Select
- Adjust volume to check this has been successful.
Program your Sky+ Remote - Sky Help
After you paired your Sky remote with your TV, check out these handy shortcuts.
We can't guarantee that every TV can be operated using a Sky remote. If you haven't found a code that works for you, ask the Sky Community.
Leave a comment
Comments have been disabled
