03 Feb 2023 04:40 PM
I am having to replace the batteries in my sky glass remote probably twice a week. This can't be right?
I have used different types of batteries. (Ie cheap and expensive).
Think it needs replacing. Only had since December.
03 Feb 2023 04:47 PM
Are they actually running out? Or are you just replacing them when the on-screen message tells you to?
There's a know bug that makes the low battery warning show up in error.
So you may have been throwing away perfectly good batteries all this time.
04 Feb 2023 09:03 AM
Posted by a Superuser, not a Sky employee. Find out moreCall sky for a replacement- I haven't changed my batteries once since April
04 Feb 2023 10:00 AM
Posted by a Superuser, not a Sky employee. Find out moreI would contact Sky and request a new remote and in the meantime if you have one available you can use a Sky Q remote.
Like you my remote chews through batteries but not to the extent yours does. Mine last about 3 weeks but as sky were having so many problems with the Glass/Stream remotes it was not worth requesting a new one so I just bought a load of cheap Amazon Basics batteries so it is not costing me much. Now Sky have a new batch of remotes I will be requesting a new one.
