10
Discussion topic: Sky glass 65inch wont turn on
This message was authored by Ellie5045 This message was authored by: Ellie5045
Went to turn the TV on there was red light but wouldn't turn on switched it off by the wall waiting 15 minutes first and then turned plug back on and now there's no red light , changed the fuse still no power ordered new cable still no power anyone else have any other solutions or has this happened to them I've only had the tv less then a month
This message was authored by bayardm This message was authored by: bayardm Answer
Re: Sky glass 65inch wont turn on
@Ellie5045
How long after replugging did you wait? It may have been updating. Wait 10-15  mins and the red light should reappear.
Sky Glass 43” stand mount, Wi-fi, 1 puck, ethernet from Bt disc.
Sky Ultimate and whole home, Diamond VIP User
BT Hybrid FTTC, BT Smart Hub 2 + 1 disc
This message was authored by Jporch316 This message was authored by: Jporch316
Call sky get a replacement under warranty
43inch Sky Glass & 3 Pucks on virgin media M250 hub 5x. Gibson les paul tribute. Fender telecaster. Epiphone billie joe .. rock on 
@Ellie5045
Ellie5045
Thanks for the reply , I recently changed Internet providers and haven't been home since the change when this has happened so will it still update I didn't manage to change the Internet on the TV before this happened
@Ellie5045
when you changed internet provider did you get a new router/hub? If so, have you linked your Glass to the new router? If not then it won't update but you should get a "no internet" message.
Ellie5045
Yes a new hub and haven't been able to change it as the TV won't turn on ?
@Ellie5045 talk to Sky and they should talk you through a hardware recovery which msy work if it doesnt they will replace the set.
65inch Sky Glass, 3 Sky Streaming Pucks, Sky Ultrafast + and Sky SR203 Wifi from 3 TP-Link Deco M4 units in access point mode
This message was authored by Taz712023 This message was authored by: Taz712023
Yes in does that but everytime we go out we have too doo this , it wont turn on with the remote, this cant be right
Hi every time we go out sky glass switches off with a flashing red light coming on, when we try too switch on with remote it wont work
This message was authored by Fothergill1 This message was authored by: Fothergill1
@Taz712023 If you go into your settings and then Start up & Standby you can switch off the Auto-standby when n motion detected option.  This will at least stop it turning off when you go out.
If my post has solved your issue please mark as an "Answer"
This message was authored by DRose1 This message was authored by: DRose1
I have noticed of late that my Sky Glass won't respond to the remote control when off. There is a subdued red light which blinks but the screen won't come on.
My resolve is to unplug for 10 seconds. This usually resets the TV and remote communication. However, the unresponsiveness is becoming more frequent.
Sky, please diagnose the problem and provide a solution.
