11 Jan 2022 10:30 PM
Amongst the many issues I'm facing with the puck the one that has been giving me the most frustration is ever since I've had the puck connected in my setup It is causing my TV (LG OLED65C9PLA) to lose connection with my Sonos arc soundbar. In a nutshell with the puck connected to my TV it causes the TV to lose connection with the Sonos arc and sound plays via the onboard TV speakers. After troubleshooting with Sonos support and removing everything else in my setup we identified that only when the puck is connected do I get the problem. Anybody else with a Sonos arc soundbar having similar issues?
30 Sep 2022 09:21 PM
Posted by a Superuser, not a Sky employee. Find out moreAs a workaround, you might want to try using a Lindy HDMI CEC Less Adapter between the puck and the TV to block the errant CEC packets being sent from the puck.
TARBAT's SETUP....................Sky Q 2tb v3 Q210 + 3 miniboxes
Panasonic 65” GZ1500 OLED TV : Yamaha YSP-2700 Soundbar (ARC) : BT Smart Hub 2 & FTTP 500/80 : BT Disc
Sky Community Superuser. 23 Years Diamond VIP
11 Jan 2022 10:43 PM
I have the Arc connected to my Sky Glass TV. I also have the Puck connected to my OLEDB8 and Sonos Beam Gen 2 with no issues either.
12 Jan 2022 10:54 AM
I have a beam gen 2 with one surrounds and no problems at all from the puck.
i do have the puck on Ethernet and not WiFi I also have my LG C1 on Ethernet too.
I'll check all my TV setting this evening and take pictures for you if you think it would help ?
12 Jan 2022 09:52 PM
Please that would be really helpful I'm certain it's related to the puck as, as soon as it's removed from the chain I don't have the problem, however it's not convenient to have to plug the sky puck in via HDMI every time to get around this issue
12 Jan 2022 10:10 PM
Puck setting and tv settings
13 Jan 2022 07:27 PM
Thanks for taking the time to post your settings, however I note with your settings you wouldn't be getting dolby atmos from the beam?
I have my puck set to passthrough
13 Jan 2022 07:29 PM
13 Jan 2022 08:01 PM
Yup I sometimes change it about a bit depending on what I watch
13 Jan 2022 08:11 PM
Did you get the arc going by the way
27 Feb 2022 04:46 PM
I have this same issue but running the beam gen 2, I have sky glass in the kids playroom and use a puck in the lounge via multi room, the lounge puck is wifi and I have no option to Ethernet it, it's mega annoying, when the puck is connected all my devices (sky, PS5 and switch) all come through the tv, as soon as puck removed from hdmi the sound comes through the sonos again has anyone found a solution?
27 Feb 2022 05:18 PM
I have the puck, LG OLED C1 and Sonos Arc.
I've noticed that with pass through enabled, I don't get ATMOS from Netflix etc.
I leave it to Auto and get ATMOS whenever its available.
27 Feb 2022 05:41 PM
I'm still having the issue, I have both a beam gen2 on my office TV and an arc in the living room (both being used with puck's) and whenever they are connected it causes the TV's to switch to the onboard audio. Both TV's are LG OLED's a 48CX in the office which doubles as my PC monitor and a C9 in the living room. I can switch back to the soundbar/HDMI eARC setting on the TV and it will work fine for a while via the soundbar however it will always revert back to using the TV's onboard speakers. Most frustrating is this also happens when watching another source, say my Apple TV or PS5/Xbox if the Puck is connected the TV will intermittently switch to using the TV speakers. If I disconnect the Puck's I do not experience this problem, I also only started to experience this since my SKY Q silver was replaced with the box, leading me to believe this issue is caused by the Puck. I'm really hoping a firmware update for the Puck's will resolve this issue.
27 Feb 2022 05:50 PM
I have just set mine to pass through and it seems to be working at the moment, I have zero confidence in it staying that way tbh
18 Mar 2022 07:28 PM
Hi - i'm facing the same issues. to solve it i have to disconnect the puck and restart my tv.
Usually happens if i'm switching my tv on and the puck at the same time.
Does anyone know whether a fix is coming? or whether there is something in the settings?
18 Mar 2022 08:43 PM
Still having the same problem here, I have tried various settings on the puck all to no avail. The only thing that stops this from happening is disconnecting the puck which is obviously not practical. I'm hopeful this can be fixed by way of a firmware update to the puck but given the plethora of other issues who knows how long it will take!
