44
Discussion topic: ITV 2, 3, 4 Sky Codes for Q Box
This message was authored by P+Tnov This message was authored by: P+Tnov
Hi
What are the codes for these in Ireland on a Q box?
I've tried everything
This message was authored by ChrisDublin This message was authored by: ChrisDublin Answer
Re: ITV 2, 3, 4 Sky Codes for Q Box
I've them working no problem here in Dublin.
10.758 V 22 5/6
10.906 V 22 5/6
Better Born Lucky Than Rich
Locked
This message was authored by Laing1 This message was authored by: Laing1
@P+Tnov wrote:
Hi
@P+Tnov  have a look at this website
P+Tnov
Thanks for reply.
However, the channels I want (itv 2, itv3, itv4) don't come up on those codes on the Q box, others do but not them.
Any other ideas? It was working fine last week
@P+Tnov you could try here
P+Tnov
Thanks for reply
I tried them, no good, same results
10.758 V 22 5/6
10.906 V 22 5/6
This message was authored by fitzerelli This message was authored by: fitzerelli
Thanks alot Chris!  worked for me.  Do you know if it's possible to manually tune in a HD channel like ITV HD?
This message was authored by Desie853292 This message was authored by: Desie853292
How do I setup the Itv channels on my Sky Q?, I'm still trying to get my head around this new system.  Thanks.
This message was authored by Dubdoc This message was authored by: Dubdoc
Would really appreciate advice on adding ITV channels on SkyQ box, With the changeover from my old sky box I have lost all manually added channels and I have no clue how to add or if it is even possible to do so
Press Home. Go down to settings.
You’ll see Maunal Tuning. Go into it and enter your pin.
Add a channel.
enter frequency etc and click find channels.
Bingo
This message was authored by Anonymous This message was authored by: Anonymous
Hi can anyone help me please with the codes for ITV1, ITV2, ITV, ITV4, ITVB and how I can do it any help would be greatly appreciated
This message was authored by Lyrah This message was authored by: Lyrah
How do I get ITV on Sky Q
Thank you
This message was authored by Rhonny This message was authored by: Rhonny
@Lyrah
Read the posts above your own.
This message was authored by Aoife+82 This message was authored by: Aoife+82
hi how do I get ITV on sky q box
Locked
