4
This discussion topic has been answered Discussion topic: which is better Sky Broadband Ultrafast Plus or full Fibre Gigafast and is it a straight swap
This message was authored by: Tmo2
current contract ending i currently have  Sky Broadband Ultrafast Plus but the next offer is full Fibre Gigafast, question is it a straight swap over at Skys end with nothing to do in home ?
This message was authored by: JimM1 Answer
Re: which is better Sky Broadband Ultrafast Plus or full Fibre Gigafast and is it a straight swap
@Tmo2 It's a change to the speed profile at the sky end, so say FF500 to FF900, software change, and fully transparent to the user as long as they do it right, know what i mean!
@Tmo2 Should be the PLUS you have is just sky FF connection speed wise with every bell and whistle that they have sold you!
Avatar for Tmo2
and re the switch over, is it someone flicking a switch or something which needs extra work at my end. installation has only been in 12 months so hopefully the former
Avatar for Tmo2
Thank you
