Discussion topic: when I uncheck the wifi box and click apply for 2.4Ghz I get message cannot connect to safari?
This message was authored by: Anita16
I am trying to split the bands  but when I uncheck the wifi box and click apply for 2.4Ghz I get message cannot connect to safari and then I cannot do anything g except press back button which just takes me back and the tick box has the tick back in it - any help please?
Re: when I uncheck the wifi box and click apply for 2.4Ghz I get message cannot connect to safari?
@Anita16
Can you try a chrome browser preferrably with an etherneted device
@Anita16 there is a bug where the web interface for Sky hubs wont work properly with Safari.
Avatar for Anita16
Level 2 icon
@cookiemonsteruk I am using iPhone and iPad which is Safari -can I  change one of these to chrome?
@Anita16
You should be able to download the chrome browser for iphone/ipad from the app store
Avatar for Anita16
Level 2 icon
Thanks for help - I'll give that a try
