Discussion topic: whats the best speed i can get in thorpe end norwich
This message was authored by: NMGNORWICH
Re: whats the best speed i can get in thorpe end norwich
@NMGNORWICH
Putting the address into the BT Wholesale Availability Checker should indicate which provisioning type is available.
@NMGNORWICH
Enter you full address below and post the table after removing your address from the image
Avatar for NMGNORWICH
wont let me post picture
@NMGNORWICH
At the minute your line can 73Mbps max with a vdsl connection
i am with sky but only get 29 do i need to change something
@NMGNORWICH
Could you post your hub stats as shown below
