Discussion topic: what connection do I need to do in Deco x55 which is directly connected to ONT , No sky HUB.
Message posted on 30 Dec 2023 08:51 PM
Hi Expert,
Need some help, Currently I am with BT and having full fibre at home. I am using the Deco x55 which is directly connected with ONT and not using any BT hub. the configuration is done as PPPoE for BT connection. Soon I will be changing to Sky fibre. So would like the same setup, don't want to use the sky router. I think to connect to sky my network type will be DynamicIP . Can someone please help what details I will be needing from sky to connect the same way , Or first of all will it work with Sky with my current setup,
Any help will be appreaciated.
Message posted on 31 Dec 2023 08:44 AM
Re: what connection do I need to do in Deco x55 which is directly connected to ONT , No sky HUB.
@mohd_tawfique Sky use a different authentication systen from BT but there have been reports of people connecting Deco units to the ONT including this post but note the DHCPv6 PD method does not work on every line as it depends on who made the kit at your exchange.
Personally I use my own Deco set up in access mode behind the Sky hub which works for me.
