7
This discussion topic has been answered Discussion topic: weak wifi signal in home office
This message was authored by: cpoaudly
I recently change to sky broadband and the signal is ok in the house but in my home/office (garage0 the signal is very week and broadband speed are very slow - what can I do to slove this - i saw "sky max pod" on the website - would this work and how can I get one?
This message was authored by: cookiemonsteruk Answer
Re: weak wifi signal in home office
@cpoaudly
Then yes it would help.  Do you already have the sky max wall to wall wifi guarantee.  Either way unfortunately you will have call sky
You can do so by dialling 150 from your sky landline number
@cpoaudly
Is the garage attached to the house or seperate?
Avatar for cpoaudly
yes it is attached to the house but there are two clock walls in between
Avatar for cpoaudly
i mean block walls
@cpoaudly
Avatar for cpoaudly
I am in Ireland and am on the line holding at the moment - hopefully they will send me one?
Thanks for your reply
@cpoaudly
Is  there any access doors between house and garage
If you have the WiFi Max subscription supplement on the account, yes.
