		Discussion topic: vpn issues using new white sky max wifi router??
	This message was authored by: chrisd123
		Message posted on 02 Oct 2025 11:12 AM
hi how do i stop my wifi from kicking me out of use on the works laptop when working from home??
Find out more
		Message posted on 02 Oct 2025 11:46 AM
							Re: vpn issues using new white sky  max wifi router??
You could also try using the Max Hub administration settings in the My Sky app to toggle UPnP: this has a side-effect of removing the 8:1 Map-T which is typically the root cause of VPN issues.
