Discussion topic: various devices and sites blocked even with shields and controls turned off
Message posted on 18 Jan 2024 02:31 PM
Luckily we have a secondary broadband service, because sky broad is shockingly bad. We are paying for the 'advanced router' which is just not up to the job.
Various devices on the network get blocked for seconds every so often, interrupting gaming
Some sites are blocked on one phone - ie Amazon Prime, while ok on another phone
This happens either with wired or wifi connections
Sky Broadband shield is off completely
We do not use MacAfee
We have a mixture of macs and windows computers
Its so bad I really just want to cancel the contract.
Message posted on 18 Jan 2024 02:54 PM
Re: various devices and sites blocked even with shields and controls turned off
@PhilC1 you will have a problem in convincing Sky to release you from contract in the circumstances you describe. Not arguing something isnt wrong but from what you describe it is not the feed to your hub which is what you are buying. As a start can you post your hub's stats. See Find your Sky Broadband router statistics
As a trial can you also add a public DNS service to a couple of devices that misbehave Google's on 8.8.8.8 works well as. Stalling you describe can be down to an issue with DNS not responding. . If they stop being a pain its a possible cause.
Message posted on 18 Jan 2024 03:51 PM
Is that the black Sky Broadband Hub or the white Max Hub?
Message posted on 19 Jan 2024 04:03 PM
I have been told that our mesh extenders where the problem. I am not so sure.
