6
This discussion topic has been answered Discussion topic: ultrafast broadband and personal alarms
This message was authored by: pjohng
What do I need to do in order for my personal alarm to work with sky ultrafast
Re: ultrafast broadband and personal alarms
@pjohng it depends on the alarm you have. If it connects via wifi it will operate as before. If it uses the phone line to connect it becomes more complicated and if you order a full fibre connection the agent will talk you through the options.
In essence with Ultrafast and indeed almost all new broadaband services the phone connection switches from being through traditional phone sockets to a voice service via the Sky hub which will have a phone socket on its back. This will allow connection of a traditional phone or alarm but only works if the hub is powered and connected. The old copper based phone lines carried a voltage that meant phones and alarms worked during a power cut. Newer alarms are designed with battery back ups and even have built-in sim cards that work when the internet is down.
The copper phone system is being de-commissioned but there are various workrounds including changing alarms etc being developed but not everything is in place yet. Currently Sky wont accept an order for a Ultrafast service if they think your alarm would not function properly.
@pjohng
What sort of alarm ? Home security or panic button etc
Alarm providers that used to provide over the copper cable should have made provisions for the change
Avatar for pjohng
Level 3 icon
Its a medical alarm so I guess I should contact them first.
@pjohng
Contact the local authority, or whoever issued the existing one.  What you are possibly looking is something like a gsm hub and neck worn panic button which should be available for rent
Avatar for pjohng
Level 3 icon
Ok thanks for that . everything I need to know
Avatar for pjohng
Level 3 icon
Good Thank you
