27 Jul 2023 08:28 PM
Has anyone had fibre installed with a block paved drive and if so do they have to lift the blocks and replace them so the drive is in its original state or is there anothe rprocess?
27 Jul 2023 08:36 PM
Could you enter your full postal address below and post the table and notes below it after removing your address from the image
It may give us an idea of how it will be delivered
27 Jul 2023 08:57 PM
Posted by a Superuser, not a Sky employee. Find out moreOurs came under a drive with brick pavers: the Openreach subcontractor did a very neat job, and it's now impossible to see any difference.
27 Jul 2023 09:16 PM
Posted by a Superuser, not a Sky employee. Find out more@ant24 I discussed the issue with the engineer doing the survey on my installation and agreed an alternative route to crossing my block paving is tgat a possibility in your home?. If your road has underground cablethe new fibre feed will come underground. Like @TimmyBGood I was impreseed by the care the engineers took.
28 Jul 2023 01:12 PM
Thanks, I'll look into that👍🏻
