Discussion topic: slow broadband can not work its so slow.
Message posted on 16 Nov 2024 07:36 AM
Sky claim my router is recieving 156mb/s
3 speed tests this morning at 7am say otherwise.
the most I get whilst in direct view of the router with everything else turned off is 13'6 mb/s.
the other 2 tests show 6.9 and 3mb/s I can not even download anything or update anything for my Photoshop or from Microsoft
which i need to do.
please help.
Message posted on 16 Nov 2024 08:00 AM
Re: slow broadband can not work its so slow.
@boogle365 can you test the speed of your hub on a device connected by an Ethernet cable? If you can that will provide a more reliable speed test or if you have a black Sky hubs posts its connection stats see Find your Sky Broadband router statistics
Can you confirm which speed test you are using as a few can give misleading results as they report MB/s not Mb/s (Bytes against bits) and have to be multiplies by 8 to convert. However assuming thst isnt the issue with your tests it is puzzling. Can you also say if you are on a full fibre connection or if your broadband is delivered over a copper line.
