Discussion topic: sky superfast internet slow
This message was authored by michelle51 This message was authored by: michelle51
hi, my sky superfast has dropped to 12 mbs and under for the last few days. how do i go about claiming a refund and asking sky to resolve this. think it should be at least 20 mbs.
Re: sky superfast internet slow
@michelle51   Please can you post your router stats so the forum can advise on any issues. This link explains how to do that https://helpforum.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/td-p/2855717#
michelle51
@GD1
This message was authored by mae-3 This message was authored by: mae-3
@michelle51
The router stats clearly show a fault on the broadband line and speed is low to the cabinet, and you should be able to either use the Sky App to do a line test or it should allow one to book an engineer to report the fault and get it fixed. Until you report the fault to Sky via the Sky App or directly by phone no engineer will be allocated to fix it and you won't get compensation.
Zen internet on G.fast (250Mbps down, 50Mbps up). SAT> IP (Apple 4K 2nd gen TV to LG C1 OLED UHD TV/Dolby Atmos Denon AVR, DacMagic Plus for Hi-Res audio), hosting own blog/forum (cluster), OPNsense & Zenarmor L4/L7 NGFW & DPI IDS/IPS, Asus ET12 Pro Tri-Band wifi, Linux, Gamer: Xbox Series X/i7 laptop, round-robin DNS over HTTPS, non-proprietary VoIP HD AMR-WB (G.722.2) and more... Beta tester Apple iOS/watchOS/tvOS/iPadOS/macOS.
michelle51
When I do a test on the sky app is says my internet is good and no option to report a fault through the app or online.
@michelle51
Even though the Sky App picks up a few faults it isn't fallible and some faults and your broadband line has a fault that it hasn't found, and the fault will need to be reported to Sky directly by phone.
