Discussion topic: sky hub + tp link deco port issues
Message posted on 05 Oct 2025 10:11 AM
hi all
i have a skyhub and a tp link be65 kit, ive setup my skyhub so it dmz to the wan IP of the tp link deco however im still getting strict nat? i dont think the dmz function is working on the skyhub, does anyone know a fix?
Message posted on 05 Oct 2025 11:04 AM
Re: sky hub + tp link deco port issues
@SpoilerN9 if the Deco is set to router mode and is in the Sky hub's DMZ the issue is not the Sky hub as you have bypassed the hub's firewall. There are any number of online guides about PS's confusing "NAT'" types in general ensbling uPNP on the router and fowarding some ports in your case it should be the Deco you need to vonfib=gure unless you have set that to Access Point mode. .
Message posted on 05 Oct 2025 03:09 PM
sky hub unup is off
skyhub dnz to deco on
deco unup on
deco on router mode
what would be the issue?
Message posted on 05 Oct 2025 03:27 PM
@SpoilerN9 You are getting a strict nat on what!
