29 Jul 2022 05:10 PM
Does anyone know is the sky fibre superfast upgrade to 1gb from my normal sky broadband as easy as just switching the box over
Ive set it up as the engineer will take two weeks to call it works fine all my devices are connected to it but my broadband speeds are the same as before around 30mbs
29 Jul 2022 05:16 PM
The sky broadband hub is backwards compatible with the old line. So you'll need to wait for the gigafast line to be activated. That means openreach still have to install the ont
29 Jul 2022 08:04 PM
I was thinking along those lines as well but wasnt sure
Just gotta wait two weeks then
