Discussion topic: sky fibre drop in speed with attached access point
This message was authored by: SpoilerN9
Message posted on 28 Aug 2025 12:51 PM
hi all
current setup is ont box -> sky hub sr203 -> asus wifi 6 access point (all wired)
when i attach my mac mini to test the speeds the speeds drop (800mbs vs 200mbs) when connected to the asus wired but are fine when connected directly to the skyhub it gets the max speed. any reason for this?
so far ive tried
lan port to lan port from asus and sky hub
made sure i have a gigabit ethernet cable
not sure what else to try?
Find out more
Message posted on 02 Sep 2025 12:25 PM
Re: sky fibre drop in speed with attached access point
Sounds like a config problem on your Asus router possibly... Is QoS enabled?
I am NOT a Sky Employee
