Discussion topic: sky broadband 5ghz to 2.4 ghz
This message was authored by: Tania124
We have bought a new device and it will only connect to 2.4 GHz but my WiFi is 5GHz
Re: sky broadband 5ghz to 2.4 ghz
@Tania124 As you do not say what Sky router you have, temp switch off the 5Ghz band, connect the 2.4Ghz device as required, if and when it is all done and if/or it works turn the 5Ghz back on. The device should stick, may just not like the single ssid both band side.
