Discussion topic: since changed to sky broadband mobile phone ran out if data
Message posted on 30 Jun 2025 08:07 PM
Changed to sky this month put the wifi on my mobile and my mums as shes on my contract thought that would be it, then discovered that both phones had used up their data allowance so had the expence of topping up then noticed that the phones keep disconnecting from the wifi then reconnecting so now it keeps using phone data when at home, I have checked the broadband on the testing page and it keeps coming up as good connection to all systems including the phones I did call sky and the customer service agent said the case will be referred to another department and it will be checked over the next 30 days but the thing is if it keeps coming up good connection on self tests what will they find and will it be corrected as I cannot keep forking out for extra data for 2 phones every month Thank you to anyone who can answer Kind regards
Message posted on 30 Jun 2025 08:09 PM
Re: since changed to sky broadband mobile phone ran out if data
To stop the data being used when at home she should turn mobile data off.
If her broadband keeps dropping and disconnecting then she could run this line test:
If this is of no help give Sky a call to report it to them.
Message posted on 30 Jun 2025 08:16 PM
Hi thank you I will do this my mum and I will also follow up your suggestion kind regards
