Discussion topic: sending back equipment
This message was authored by kayharley1990 This message was authored by: kayharley1990
I have just received the box to send back my broadband hub but its not big enough and it weights more then what it should
Re: sending back equipment
@kayharley1990 there are multiple models which vary in form but as you are not paying for the return carraige weight is not an issue for you. Use what ever packaging you can find but make sure it is well packed and you use the labels Sky provide. The risk of breakage is fairly low as the units are pretty tough. Keep your proof of postage
