09 Feb 2025 03:51 PM
Has anyone else noticed the "remote management" option has been removed from the router.
Can no longer access the router remotely.
Anyone know why this has been removed and Is there a work around??
Thanks!!
09 Feb 2025 04:09 PM
https://helpforum.sky.com/t5/Broadband/remote-managment-stopped-working/td-p/4905592
09 Feb 2025 05:30 PM
thanks for replying so quickly.
Frustrating that regs have changed to disable this feature. Do you know if theres another way round this with port forwarding, etc. or will this be completely blocked? I replied on this feature a lot and now finding it a real issue.
Cheers
10 Feb 2025 12:09 PM
Hi, does anyone else know if there's a "way around" this remote management removal, port forwarding, etc? Just need a way to be able to log into my router remotely, surely not too much to ask 😄
Seems like all ports have now been closed? seems a stupid rule change - this was for "advanced users" that would specifically have to check the remote management box to enable it?
Thanks!
