08 May 2024 06:20 AM
I am getting this appear on the service checker above, but when I continue with all the other checks after the problem is not then detected? As below
Yet when I go back to the service checker the problem is still there?
08 May 2024 07:08 AM
Posted by a Superuser, not a Sky employee. Find out more@FranGeorge unless you are experiencing problems in using the network there is no need to worry. If you are why not post details and forum members can try to help?
08 May 2024 07:59 AM
I have exactly the same problem. I can't connect anything. I have tried all the troubleshooting guides, soft reset, hard reset and nothing will connect, no green Internet light. Sky troubleshooter says problem with WiFi but then goes on to say all good but 0 connected devices. Been like this since 7am
08 May 2024 08:03 AM
08 May 2024 08:09 AM
Same. All lights on router, nothing connects to WiFi.
08 May 2024 08:10 AM
Posted by a Superuser, not a Sky employee. Find out more@R0gu3tr4d3r the leds on your hub as they will tell you if there is a wifi problem in your home or more fundamentally if the internet light is not green that the hub has simply not connecting the the exchange - different problem different advice see https://www.sky.com/help/articles/hub-lights-explained-start
Line issues need to be reported to Sky whose lines are now open.
08 May 2024 02:02 PM
Mines doing the exact same, still not on
09 May 2024 01:39 PM
Posted by a Superuser, not a Sky employee. Find out more@Tammy942 @FranGeorge @Jarvo12321 @Russ9
If you can't access the internet & your Sky Service checker is saying problem with the 'WiFi' then it may work if you unplug your router & then run the check again. This way the Sky checker many identify something different when it can't connect to the router.
25 Aug 2024 01:02 PM
I'm having the same problem. Upgraded the router as poor Wi-Fi upstairs. Still can't get Wi-Fi to connect when using wattsapp, Facebook, Snapchat. Nothing will download. SkyQ working fine as is the internet. How can this be solved?
25 Aug 2024 01:37 PM
Posted by a Superuser, not a Sky employee. Find out more@maars Are you new to Sky?
25 Aug 2024 02:18 PM
@highlinder
no I've been with Sky for 14 years.
I've turned off the router so many times but still have the same issue.
25 Aug 2024 02:25 PM
Posted by a Superuser, not a Sky employee. Find out more@maars Are you able to check your broadband sheild settings?
