Discussion topic: problem with broadband high noise margins and maybe issue with router
This message was authored by: loverboi
System Detailshelp
ManufacturerSky
ModelSR203
Firmware Version7.03.0704.R
DSL Firmware VersionA2pvfbH043p1.d26u
Modemhelp
Modem StatusConnected
Traffic Type:PTM
Line Rate - Upstream (Kbps):5998
Line Rate - Downstream (Kbps):34999
IPv6 Loopback Address2a02:c7c:dfd6:6c00::1/128
Broadband Porthelp
MAC Address3c:45:7a:fb:53:3a
IPv4 Address5.68.215.250
Network TypeMER
IPv4 Subnet Mask255.255.252.0
Gateway IPv4 Address5.68.212.1
IPv4 Domain Name Server90.207.238.97, 90.207.238.99
Gateway IPv6 Addressfe80::22
IPv6 Domain Name Server
IPv6 Global Address2a02:c7c:dfd6:6c00::1/64
IPv6 Link Local Addressfe80::3e45:7aff:fefb:533a
IPv6 Delegated Prefix2a02:c7c:dfd6:6c00::/56
LAN Porthelp
MAC Address3c:45:7a:fb:53:39
IPv4 Address192.168.0.1
DHCPv4On
IPv4 Subnet Mask255.255.255.0
IPv6 ULAfd63:77b2:5afa:0:3e45:7aff:fefb:5338/64
IPv6 Link Local Addressfe80::3e45:7aff:fefb:5339
DHCPv6On
WiFi Porthelp
Name (SSID) SKYJNS2K
Region Europe
Current Channel 11 (2.4 GHz), 36 (5 GHz)
WiFi AP Enabled
Broadcast Name Yes
Connection Status       Show Statistics
Connection StatusClose
Connection Time16:33:17
Connecting to ServerConnected
NegotiationMER
AuthenticationAUTO
IPv4 Network Mask255.255.252.0
IPv6 Link Addressfe80::3e45:7aff:fefb:533a
Router Statistics
System Up Time: 16:35:19
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN MER 1877255 3300035 0 0 0 16:33:43 LAN Up 3050839 5019774 9 2 2 16:35:19 WLAN (2.4 GHz) Up 320646 4083 0 0 0 16:26:34 WLAN (5 GHz) Up 16664810 8313074 0 2 1 16:25:01
Broadband Link Downstream Upstream Connection Speed 34999 kbps 5998 kbps Line Attenuation D1(13.9 dB) , D2(36.3 dB) , D3(57.1 dB) U0(5.3 dB) , U1(28.9 dB) , U2(45.3 dB) Noise Margin 14.4 dB
10.1 dB
my speed to hub but it sometimes says issue with wifimy speed to hub but it sometimes says issue with wifi
it sometimes says there is issue with my broadband/wifi too is that a sign with tha issuse with line or router but sky done line test and they said there no fault but i think otherwise with my noise margin and speed to hub i was getting 37.5 then it went to 36.8 then 36.2 then today 31.8 is it a issue with line or router? thanks advice and help with issue will be very appreciated and thanks in advance have a great day 😞  🙂
Re: problem with broadband high noise margins and maybe issue with router
Hi @loverboi
Your stats certainly show an issue as your line is banded and it should not be changing sync speeds that often.
It will need reporting to Sky, you can either call or I can esclate your post on the forum and you can chat with a Sky rep.
I am NOT a Sky Employee
Avatar for loverboi
Level 6 icon
@jamesn123 yes please can you escalte please and when i called sky they told me to reset the router that i did and then left overnight and still high noise but i called them today twice and was told there is no fault so we cant get openreach out but they blamed the low speed to hub on 6 devices connectedand i said that due to the low speed to hub pics on messenger is taking about 5 mins to show the bloke said mehh:(      (im on fttc)and they blamed it being that and not amitting to a issue 😞 🙂
Avatar for loverboi
Level 6 icon
@jameshi may i ask hs it been escalated and please any info please
