Discussion topic: port forward not working hub 6
This message was authored by: ColinK1306
trying to get port foward working on hub 6
configured in ap, device is on line and confirmed, no access
also tried using dmz still no connection, as a further note even with remore access enabled for testing cant access hub remotely either
Re: port forward not working hub 6
Avatar for ColinK1306
thanks but thats not the issue
i have the new hub 6 which forward is done on the app, all set up but doesnt work.
@ColinK1306 was it all working ot the previous hub, an what one was that?
Yes worked fine on old black Sr 203 hub
I can see from the hub log that it's gwtti
@ColinK1306 If it is not working then you may have to get sky to have a look at the Map-T settings that are applied to your hub.
