Discussion topic: poor network connection during peak hours - unable to use phone apps and TV connection dropped off
Message posted on 04 Jul 2024 07:24 AM
poor network connection during peak hours - unable to use phone apps and TV connection dropped off twice last night -
Message posted on 04 Jul 2024 07:33 AM
Re: poor network connection during peak hours - unable to use phone apps and TV connection dropped o
@GaryB1905 sounds like your home has a lot of wifi interference probably from your neighbours' networks. You can try rebooting your hub to find the least congested channels but in flats or similar homes with lots of other users close by that can be almost impossible.
You can download a Wifi Analyzer app onto a phone which will show you what networks are in range with their channel and signal strength meaning you can find the best channel in the area near the TV. This link tells you how you can change the channel on the black Sky hubs https://helpforum.sky.com/t5/Broadband-Talk/How-to-change-your-Sky-wireless-channel/ba-p/2687733
There could be other causes but issues which are worse in peak times is usually interference.
