Discussion topic: orange voice light won't go out.
This message was authored by: Grampy1
orange voice light on sky hub stays on, this effects my hive app on my mobile which now will not work. Why?
Re: orange voice light won't go out.
@Grampy1 Is the Internet light out at the same time the voice is Amber per chance?
Avatar for Grampy1
No i get 3 green lights and 1 amber voice light.
@Grampy1 When you get that Amber on for the voice, is the Internet connection gone?
Avatar for Grampy1
No i can still get the internet, although very slowly.
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
Avatar for Grampy1
Thanks i'll try that.
