Discussion topic: number of devices I can connect to
This message was authored by: SPRINGHEAD
HI, we have over 18 devices connectied and I think there is a limit as wont let me add any more!
could you increese that limit to 35?
Re: number of devices I can connect to
Any such limit would be inherent to the WiFi hardware and not something subject to change by an ISP without replacement by a different model.
Which Sky Hub model do you currently have?
Avatar for SPRINGHEAD
Hi, thanks for replying
Model nr SR203
@SPRINGHEAD the Sky Broadband Hub SR203 does not have a hard connection limit. The practical limit depends on the type of devices, the number in use at any one timecand pretty obviously the bandwidth of the connection. You can have lots of IOT devices without issue but numbers will drop with say half a dozen  users playing online games or streaming viideo at once.
What is you issue? Sky support use the too many devices excuse quite frequently which has a basis in truth but is not a simple limit.
That's great help, thanks for that
