29 Jul 2023 05:40 PM
I have just set up the new sky SR213 router for sky wifi max, and when I went to the router settings via the browser, I discovered that the port forwarding settings had been 'moved to the app'. So I looked in the my sky app for this supposed new location for the port forwarding settings. However, I can't find them anywhere and I'm still stuck with the ports I had open on my old router being closed. Am I just blind and unable to find the setting, or is this a recurring problem?
29 Jul 2023 05:59 PM
Posted by a Superuser, not a Sky employee. Find out moreAs mentioned in the Sky help;
The Sky Max Hub doesn’t support DMZ or Port forwarding at the moment.
https://www.sky.com/help/articles/change-wifi-max-hub-settings
03 Aug 2023 08:47 AM
I've been trying to open a port for a while on my new sky max router and finally came across the comments above... will this be enabled to allow port forwarding?
03 Aug 2023 10:50 AM
Posted by a Sky employee24 Sep 2023 11:26 PM
So I've just been trying most of the day on and off to figure how to be able to join Xbox Live parties. Games install and it loads the store but trying to queue for matches or talk it doesn't allow. It comes back with Teredo IP not available. So I was looking around online and it suggested port forwarding which as listed above isn't supported. My only option that worked was allowing UPnP which having read about it seems to pose serious security risks. Having just moved to Sky from Virgin this past month due to change of adress I don't understand why there's been so many issues. In the first month I've had more interactions with the support staff than my decade with Virgin media. If anyone has any advice or can help me in any way I'd truly appreciate it as I'm not particularly knowledgeable in these areas.
thanks
26 Sep 2023 11:41 AM
Posted by a Superuser, not a Sky employee. Find out more@MadnlooneyJR UPnP is enabled by default and isnt a security risk as such.
There should be no port forwarding/configuration required for you to be able to use your Xbox.
How is it connected to the router? WiFi or Wired?
30 Sep 2023 05:24 AM
Thanks for responding it's via Wi-Fi and prior to needing to add a Wi-Fi booster it worked but would drop connection hence the need for the booster. Ever since the booster has been placed it doesn't seem to allow chat functionality at all. All other systems appear to work fine I can see others online and make purchases and downloads. So I'm not sure if the booster is affecting it or not.
Thanks for the response and apologies for my delay in responding.
03 Oct 2023 10:45 AM
Posted by a Superuser, not a Sky employee. Find out moreIt does indeed sound like it could be the booster causing the problem. Are you able to try without it? Either via direct WiFi again or ethernet?
14 Oct 2023 10:39 AM
Kev,
I've just moved to Sky and have got the Max Hub (SR213)
You state that Port Forwarding & DMZ functionality will be added in the future.
Do you know if there is any timescale for this upgrade?
Regards,
Colin
17 Oct 2023 02:30 PM
Posted by a Superuser, not a Sky employee. Find out moreSky have not announced a timescale AFAIK
17 Oct 2023 02:39 PM
James,
Thanks for the update. The help team at Sky could not help either. Nor could they swap out my Max router, for the older 'Broadband' router.
So, I'm afraid I'll have to look for another ISP 😞
17 Oct 2023 02:41 PM - last edited: 17 Oct 2023 02:42 PM
I'd think they should be able to do so by removing the 'Max' add-on, but the default would then be a Q Hub unless 'Broadband Boost' was added (or the connection technology requires a Broadband Hub)
17 Oct 2023 02:45 PM
Timmy,
I thought that as well, but sadly no. It would just just remove the WiFi Max guarantee. They would not let me have an old 'Broadband' router.
The only way thay said they could do it was to cancel my current contract and then apply for a new one. However, this might mean up to 2 wekks without any service.
Shame the processes are so inflexible.
17 Oct 2023 02:49 PM
Posted by a Superuser, not a Sky employee. Find out moreYou have a right to cancel within your cooling off period so I am not sure what Sky are playing at. The whole Sky Max release has been an utter shambles IMO.
08 Nov 2023 10:37 PM
I have the same problem where i cannot port forward and i need to be able to do this.. cant connect to friends on xbox ... this needs sorting fast !
