Discussion topic: no internet connection since july 4, 2025
This message was authored by: ICEBII
I already sent and email sky for technical issues wherein our sky fiber dont have internet connection at all since july 4, 2025.
Re: no internet connection since july 4, 2025
@ICEBII
Sky don't use email for general communication or fault reporting.
If your broadband still isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
