Discussion topic: my socket where the purple cable (master microfilter) should go is from Virgin medio, can I use it t
Message posted on 29 Jan 2024 01:23 PM
Hi. My socket where the purple cable (master microfilter) should go is from Virgin medio, can I use it too?
Please, could you tell me?
Message posted on 29 Jan 2024 01:34 PM
Re: my socket where the purple cable (master microfilter) should go is from Virgin medio, can I use
Typically not: Virgin Media have their own network and (in most cases) don't use Openreach data cabling.
Message posted on 29 Jan 2024 01:35 PM
Have you orderd broadband from Sky at that address, and has the activation date arrived?
Message posted on 29 Jan 2024 01:38 PM
Ok, I understand. Wher can I fix that Master Microfilter, please?
Message posted on 29 Jan 2024 01:43 PM
Yes, I did it. Everything came...the only problem is the socket to fix that Master Microfilter, it's missing? I have just openreach but I can't fix it in
Message posted on 29 Jan 2024 01:47 PM
If there's a missing or damaged faceplate then you'll need to report that to Sky.
If you have an unfiltered master faceplate then you may require a plug-in microfilter which ISPs don't supply any more.
Message posted on 29 Jan 2024 01:55 PM
Ok. The only one I have on the wall is from Virgin medio?
Message posted on 29 Jan 2024 03:06 PM
If there's no Openreach socket at all then you need to report that to Sky: unfortunately it may have been removed when Virgin came in, but there's still a record of it at the address.
