Discussion topic: my sky router internet light is either flashing or solid amber
This message was authored by: Ross100114
Re: my sky router internet light is either flashing or solid amber
@Ross100114 Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
