Discussion topic: my pc is not showing on port forwarding
Message posted on 02 Jul 2024 08:49 PM
hi iam trying to host a game on steam bou i can not set up port forwading on the sky app its not finding my pc
Message posted on 03 Jul 2024 07:21 AM
Re: my pc is not showing on port forwarding
@parody do you have the white Sky Max hub by some chance? If you do it can be frustrating if you cannot find a device to set up port forwarding look carefully at the list of devices as the PC maybe there but showing a different name as the hub can show the network card details instead.if it is definitely not listed after a rdboot you will havecto call Sky to see what they suggest. My own wifi max hub seems pretty random at picking up devices.
