Discussion topic: moving ISP need to know WAN details
This message was authored by robertkwild This message was authored by: robertkwild
hi all,
im moving from Zen to sky BB
is anyone on sky here and have they setup there opnsense with it?
ive seen this guide
https://docs.opnsense.org/manual/how-tos/SkyUK.html
anything else i need to know
thanks,
rob
Re: moving ISP need to know WAN details
@robertkwild
The doc looks fine to me, should work
I am NOT a Sky Employee
robertkwild
i have googled around and aparently you can type in anything in the dhcp client identifier
anything@skydsl|anything
is that true?
@robertkwild
Yes thats correct. The string that has worked for me in the past is abc12345@skydsl|abc12345
robertkwild
i dont understand then, if you can put anything bogos in the string whats the point of it?
@robertkwild the string doesnt matter anything works but you seem to need the @skydsl section in the user name.
@robertkwild
Its about presenting the right format of characters to Sky's authentication servers
robertkwild
but surely anyone without sky can put this string in, then they will get sky BB or no...sorry for the stupid question
is there a way to get your actual sky BB username and password then
@robertkwild there used to be a specific log in you could find and use but Sky now authenticate on the line which is connected back to their servers.
@robertkwild
I believe if you extracted the actual client identifier string you would get
Mac_address@skydsl|last 6 characters of mac address
But the one you quoted works fine
robertkwild
thanks guys appreciate it
what about the other info, do i need them ie
dhcp-class-identifier
DHCP Unique Identifier
@robertkwild you shouldn't need anything else just follow the guide you linked to and it should work assuming you are in the UK Ireland is different.
@robertkwild
That info isn'nt required just client identifer option 61
robertkwild
nice thanks so just option 61
let you know when im connected as my switchover from zen to sky is tomorrow
No because your line still needs to be connected to Sky's kit back in the exchange
