04 Feb 2025 12:42 PM
I use a desktop computer and an ethernet cable connection, while on average the ping is under 20ms it it will spike, around every 10 seconds ping to the hundreds, and then return to normal. These spikes can last anywhere from a few seconds to up to 20 seconds at a time and have been a major issue for the last few weeks. I tried using a wireless wifi booster to help but that didn't make any difference. I have tested the wifi over a few weeks and it has yet to improve.
04 Feb 2025 12:48 PM
Posted by a Superuser, not a Sky employee. Find out moreHi @Brawl
Please provide a speedtest taken on speedtest.net using the PC in question while connected via ethernet.
Please also let us know what other devices are conneted to your hub & via ethernet?
04 Feb 2025 03:01 PM
Hi,
The link to the test from that site will be below but the problem is that it is not a continuous test so it does not show the spikes. I use a continuous internet speed tester regularly and the results of those tests over the last few weeks show how the internet regularly spikes from the usual 20ms, into the hundreds.
04 Feb 2025 03:21 PM
Posted by a Superuser, not a Sky employee. Find out more@Brawl are other devices using the connection at the time you get the spikes? These may not be in active use but coukd be uploadingbor downloading as background activities.
04 Feb 2025 03:56 PM
Posted by a Superuser, not a Sky employee. Find out moreWhat is the speed of your line? That result doesnt make much sense to me. If an FTTC line is getting 18mbps upload it should be getting a higher download than 48mbps. You said your connected via ethernet?
04 Feb 2025 06:37 PM
I have the Sky broadband superfast package, I can't find an exact number for what I should be receiving, sky seems to be stating that on average I am getting 71mps but I have never had speed that fast. there are 9 devices in the house but there are only ever 3 being actively used at one time and this issue has only been happening for the last month. I use a TP-Link powerline extender to connect my pc to the internet using ethernet and I have had no issues with this until recently, I also tried switching to a wireless option and it had the same issues.
The lag spikes also occur when I am the only one in the house and only one device is using the internet.
06 Feb 2025 03:49 PM
Posted by a Superuser, not a Sky employee. Find out morePowerline relies on the electrical conditions in your house which can change at a moments notice. You would need to connect via direct ethernet for a reliable result/test
