15
This discussion topic has been answered Discussion topic: issues with sky hub and linksys velop
This message was authored by: Stevemk2
Hi all
I know that i cant use my black sky router in modem mode and currently the internet on my velop system is very intermittent, is there anything i can do?
My velop was reset to factory setting (what a pain that was to get working  again) and its worked ok for a bit but yesterday its brought this fault up, its coming up with no internet but i can access it fine.
thanks
Avatar for Stevemk2
This message was authored by: Stevemk2 Answer
Re: issues with sky hub and linksys velop
I don't know much about this, no, I'm just kinda winging tbh but it does seem to have sorted it out tho
@Stevemk2 Your sky hub is up and connected to the internet fine?
Avatar for Stevemk2
Yeah the hub works fine, I can use it on my device and my hard wired stuff works but the velop it's self comes and goes
@Stevemk2 Do you have the sky hub as the primary and the velop as a secondary connected to the sky hub, Ethernet connected Wan of velop to Lan off the sky, Router Mode, AP mode, etc which way is it?
Avatar for Stevemk2
I have the cable coming into the sky box from the fiber box, then another cable goes to my primary tower, I don't have it plugged into the wan port, should I?
The router is how it was delivered, I've been in the settings and I'll I can find is change password and turn WiFi off
White cable to fiber
Black to velop
@Stevemk2
I'd note the ethernet from the ONT is supposed to connect to port #4 on the Sky Hub.
@Stevemk2 Hard to see what you have done, and how you have it all working but the ONT lan cable goes to the Sky hub and it is marked WAN on it and is the very Right hand RJ45 Port 4 connection, can not see it from the picture you sent so go take a look yourself...
Avatar for Stevemk2
Thanks for your reply, what is the ONT, is that the white box the fibers comes into?
@Stevemk2 Yes, ONT little white box, SR203 your model off the sky hub, lan off to your velop system!
Avatar for Stevemk2
I have the cable from the ONT going into port 4 Wan
And the another cable off to the velop system from lan port 3, does it matter what port I use
@Stevemk2 No you can use any off port 1,2,3 for the connection to the velop.
Avatar for Stevemk2
Thank you for your help, not sure if it's anymore stable, but will find out soon
@Stevemk2 If not you may just have to go look on the velop side, do not mean to be blunt, but do you know what you are doing from some off the replies i suspect not!
Avatar for Stevemk2
@Stevemk2 It's not an issue, easier to know where to pitch the response level at, i've been doing it 45+ years so keep forgetting to tone it down and not make assupmtions that people already know, that's all MY mistakes nothing to do with you!
Glad to help, you need anything just shout!👍
